marpel's avatar
marpel
Electrical Help Needed
As part of correcting a no brake issue on our trailer (small 23 foot), I decided to freshen up and rewire some components of the braking system.
I will quickly admit, I knew/know very little when it comes to the intricacies of trailer electrical system(s) and I am learning "on the job". So far, I have replaced the 7 pin cable, junction box, emergency brake cable component and run new brake wiring from the junction box to each of the four, soon to be replaced, brake assemblies. All the wiring has been laid out, but many actual connections are still pending.
One of the latest stumbling blocks is a small device at the front of the trailer (previously hidden under an amateurish bo-jack cover which is like a hand formed thin plastic cover, open to the elements at the bottom - original to the trailer). It is attached to the front frame cross member, is about 2 x 1 x 2 inches high, and has two threaded studs, to which four cables are attached by ring terminals. I was unable to fully inspect it, due to impending darkness, but it has BAT etched in it, and one of the wires goes to the black wire of the 7 pin cable. I think another wire goes to the battery, but can't confirm that yet (due to wire loom). It is located right beside, but not connected to, a grounding screw in the frame. Because neither the grounding terminal nor this device are protected from the weather, there is noticeable corrosion.
At the very least, I will be cleaning up the corrosion, but don't know yet what else needs doing.
However, I am trying to determine what this device is, what it does and, whether it can be just cleaned up or needs replacing. Have done some internet searching and came up with either a busbar or stud type circuit breaker (the closest photo I could find is a Princess Auto 6 to 24v stud type circuit breaker).
Any help is greatly appreciated, and sorry for the long post.
Marv
