JBarca
Jul 06, 2013Nomad II
Hi Edzzed,
OK pics showed up while I was posting.
Can you please tell us which pic goes where on the camper? It is a whole lot easier to help if we know what pic goes where.
Or better make a diagram, here is mine
I would do the 4 foot level check o the axle tube and tell us which pic goes to which tire. Get all 4 tires.
Also heads up, you might want to run over a truck scale and get a certified weight slip before heading to the truck shop. Split the axles on the scale to get a front and rear axle weight and individual wheel weights. Make sure all the toys and weight are in it adn teh WD hitch is engaged
Like this
Then split the front and rear axle on 2 scales
Then ideally find a scale where you can get individual wheel weights. pull 1/2 on and 1/2 off and split the axles.
Campers are not built even left to right and all 4 wheels can have different weights
One never knows how good or bad you are until the scales tell you. Trust me, every time I go, where the heck did that weight come from??
Good luck
John
Like this
Good luck
John
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 03, 2026
