Bob_Vaughn's avatar
Bob_Vaughn
Aluminum Rims
I have a 2011 5th wheel with aluminum rims. What cleaner works the best to get them clean and shinny again.?
  • If the wheels are made by Alcoa there is a code stamped on them that you can decipher to see if they are clear coated or not. It's been awhile since I did it, but the details were on their web site.
  • Some aluminum rims are clear coated. If your are, using any type of polishing compound will remove it and be a lot of work. Using one of the wheel cleaning products from the auto parts store is about as good as you can do.
    If you really want to polish and clear coat isn't used, Mothers makes a very good polish and using their polishing ball in a drill really helps. This is what I use on my Vette wheels.
    I believe you can Google it and get several step-by-step sites.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
