rexlion's avatar
rexlion
Andersen No-Sway Hitch ride comfort question
Ok, this question is strictly about ride comfort. Jiggle reduction. I'm already well aware of the Andersen's construction, operation, potential drawbacks, etc.
My wife can't stand the jiggle when towing the TT. It's to the point where she won't let me tow when we travel together. We try to visit family 1000 miles away (OK to MI) each summer, and that trip is coming up soon, so I'm looking for a way to take the TT. I do not like motels! DW's internal problems medically mean that the ride even w/o TT is uncomfortable, but tolerable. With the TT (when we last did it that way) she was in pain.
So I'm asking you Andersen owners out there. Let's say the jiggle with just your tug (no trailer) is a zero, and jiggle with the TT (but no Andersen) is a 10. What number would you assign to the jiggle factor on your rig WITH the Andersen installed?
Details about your rig are welcome, too. Mine is in the sig (Toyota Highlander was chosen for its ride comfort on the road along with its 5000 lb tow rating, and it has done the job well for 138K miles).
  • You can also look up air ride seats, I was looking into them because my wife too has some internal issues when it comes to jarring action. Cant remember the name of the company but type in air ride seats into google and that should turn up some results.
    Good Luck! Aint nothing worse than Hotels/motels!
  • Thanks ktmrfs for mentioning the Air Safe, it's an option I was not aware of.
    TomG2, you're right, that does sound exaggerated! :D But encouraging, too.
    Ron, although I still have the Equal-i-zer I do not believe it would work well with our current rig. The jiggle is the nose and rear being levered up/down when going over expansion joints and bumps, and of course there's some jarring sensation there too. I'm just towing on the ball. The Equal-i-zer on the old rig maybe did help some with the porpoising (jiggling), but the jarring sensation on bumps was still bad. I can recall the ride still being horrible on rough stretches of highway; we sold that trailer in early 2008. My KZ GVWR is 2800 (just verified on sticker), UVW 2180, and after loading for camping it's got to be approaching that number so that's what I gave; I do have the optional 14" wheels, so the tires aren't the weak point.
  • Mike,
    Your "signature" indicates you are towing a 2011 KZ Spree Escape E14RB.
    This website says the GVWR for that trailer is 2700#.
    If you do have a towing weight of about 2700#, the tongue weight should be around 350#.
    In another thread, you stated you previously towed a 4000# trailer using an Equal-i-zer WDH rated for 1000/10000#.
    Did you also have the "jiggling" problem with the previous trailer?
    Are you using the 1000/10000# EQ with the Spree? If so, it is much too stiff.
    Can you elaborate on the "jiggling" problem?
    Is the TV bouncing up and down (heave)?
    Is it rocking side to side (roll)?
    Is it rocking front to rear (pitch)?
    Reducing the heave and pitch motions often requires just a simple re-adjustment of the WDH.
    Ron
  • "...... Let's say the jiggle with just your tug (no trailer) is a zero, and jiggle with the TT (but no Andersen) is a 10. What number would you assign to the jiggle factor on your rig WITH the Andersen installed?"
    You may think that I am exaggerating, but the answer is "zero" or the same as or better than running solo. The urethane "springs" settle down the jiggles or what some call "porpoising". Those who have not tried it will argue, those that have, won't.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    If the anderson won't solve the "jiggle" problem, consider an "air safe" air hitch. Not inexpensive, but in our case dramatically improves the "jiggle" and ride quality. Especially noticeable on bad concrete sections or frost heaves.
    And good quality shocks can make a big difference as well.
    don't know if anything will make the ride as smooth as not towing though.
