MiRvn's avatar
MiRvn
Anonther Atwood Fridge Failure
I need some help trouble shooting my Atwood fridge.
First off, last fall it crapped out and left us running on propane only. It was flashing a code. I pulled the circuit board cover and noticed a fuse was blown. I changed the fuse and all was better... Until now.
Now it flashes NO codes. It appears that all is well but it's not getting cold at all on neither gas nor AC. I can see a flame when on gas and the flue is warm. I pulled the thermister to make sure it wasn't that. I really don't want to take it to the dealer. I don't trust them and I don't want to pay their prices.
Would replacing the element make a difference? We are camping this weekend and a fridge is good for keeping things cold.
  • That's why we always use 120 volt power to troubleshoot- the flame on these is so small, that it is impossible to determine if the unit is getting enough heat- on 120 volt power, we can calculate the exact amount.
  • I was able to notify Atwood and they did extend the warranty until I could get the unit into the dealer. Unfortunately I couldn't get it into the dealer in a timely manner so I ended up ordering a new heating element and a thermistor. The heating element did the trick! I can't explain why it would only work on LP sometimes, but since replacing the element it hasn't given me any problems since.
  • The warranty on Atwood refrigerators is two years. Contact them at 800-546-8759. They've done warranty work for me before, and they are very helpful.
    Jim
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    jerryjay11 wrote:
    I know you are talking about a 2015 refrigerator, but if you have a flame it should be cooling. It isn't any electrical problem. You may have developed a leak in the refrigeration system. Yes even on a new unit. That's what the warranty is for. One tell-tale sign of loosing the coolant is a gurgling sound unless all the coolant is gone. But these units don't require any electrical components other than the electric heater element to produce cooling. And you have stated both the electric and gas are working and not getting it cooled.
    Look at your Atwood warranty to see how long it covers and go to an RV dealer. I had a bad refrigeration unit on mine that I had to diagnose for the dealer before getting it replaced.
    I agree, it sounds like it no longer has helium in it if everything else seems ok. Going to a dealer is your best bet.
    Mine is a 2014 and it has worked flawlessly; it's on 6-8 months a year, mostly on electric.
  • I know you are talking about a 2015 refrigerator, but if you have a flame it should be cooling. It isn't any electrical problem. You may have developed a leak in the refrigeration system. Yes even on a new unit. That's what the warranty is for. One tell-tale sign of loosing the coolant is a gurgling sound unless all the coolant is gone. But these units don't require any electrical components other than the electric heater element to produce cooling. And you have stated both the electric and gas are working and not getting it cooled.
  • HERE is most current 'guide' for your Atwood Fridge
    When a 'fuse' on control module is found blown it usually points to other issues downstream
    AC Fuse.....electric element
    DC Fuse.....controls or circuit board
    Lack of sufficient cooling
    Ventilation....obstructions, lack of draft
    Bad electric element or wiring connections
    Dirty burner, dirty flue/flue baffle, low propane pressure
    Faulty thermistor
    Read thru the guide then do some troubleshooting.
