Mike_Up's avatar
Mike_Up
Any horror stories with a Blue Ox Sway Pro, new design....
with the none adjustable head tilt, and rotary brackets??
I'm almost ready to buy but read of one horror story but owner may of had the nose high on the trailer when setting up.
My Reese Strait-Line (High Performance Dual Cam) is 8.5 years old and I've had issues of getting it adjusted correctly. Initially the bars were hitting the cam lobe brackets on my 19BH 22' TT but I just paid attention not to turn to sharp.
When put on my my 26BH 29' trailer, they hit the cam lobe bracket or the threads of the ball, and broke the head. Dealer adjusted it poorly. I did have to use larger spring bars for the heavier tongue weight. Went from 800 lbs to 1200 lbs, no 1000 lbs option unfortunately.
Dealer replaced head and readjusted it to have the bars swing lower as not to hit the cam lobe brackets but then I have the head tilted toward the trailer at a steep angle and only have had 2 spare links on the chain. That was with my 2010 and 2012 F150s (same truck basically, just different engine).
I really don't want to deal with adjusting this thing again for the new truck. I really don't trust it all that much.
So I've heard great things about the blue ox sway pro and I'm pretty much ready to buy, but still a little hesitant.
I just want to know if anyone had some really bad issues with the "NEW" designed head and rotary bracket.
Thanks everyone.
  • DinTulsa wrote:
    I have the blue ox sway pro on a 37.5 ft 10,800 TT and it is a great hitch. I've never towed with a different WD\Sway hitch though.
    I am getting ready to put it on a 37 foot, 12K trailer....glad to hear you are happy...
    What is your TW and which bars are you using?
    Thanks
    Dan
  • I have a new style Blue Ox Sway Pro on mine and it is great super easy to hook up.
    You can do the chain brackets (on and off) by hand no need for the wrench if you use Power Tongue Jack to raise trailer and TV.
  • I will echo the comments as well. I have a 35ft, 9500lb trailer and love my SwayPro.
  • I'll echo these comments. Works great, had problems with the retaining pins, and always got new ones gratis. Great customer service.
  • I have the blue ox sway pro on a 37.5 ft 10,800 TT and it is a great hitch. I've never towed with a different WD\Sway hitch though.
  • Community Alumni's avatar
    Community Alumni
    carringb wrote:
    I like mine. The little springs that hold the pins that secure the WD bars both broke. I just replaced them with rubber bands. The I bolts attaching the chains are worn and I plan on replacing those. I have ~2 years and 20,000 miles on the setup.
    No need to rig the retainers. There's a lifetime warranty on the hitch.
  • I really like our Blue Ox. Had a Dual Cam for the past 10+ years.
    The Ox is easier to set up than it is to change a light bulb...(almost)
    Not sure about how it does it, I was skeptical about the engineering, but I get absolutely no sway.
    If there is a negative at all, it that the hitch head is heavy and a little hard on my creaky knees.
    Great hitch. Blue Ox is really on to something with this one.
  • I like mine. The little springs that hold the pins that secure the WD bars both broke. I just replaced them with rubber bands. The I bolts attaching the chains are worn and I plan on replacing those. I have ~2 years and 20,000 miles on the setup.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 23, 2026
