wa8yxm
Aug 23, 2022Explorer III
I have parked on ONE site that was not wide enough but it was still not a problem
The rig beside me also extended "over the line" with his slides out so to walk between (IE to access hookups) you walked a "Z" pattern That's in 15 years
Had a few where I had to pull forward/back a bit
The advantage.
You level. then extend slides on ONE side. the rig may "Tilt" that way
Slides out on both sides. Tends to be easier to keep level
The advantage.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
