dcason's avatar
dcason
Any maintenance needed on propane tanks?
Just asking because I thought I read there should be but hubby doesn't do anything and being that this is flammable stuff we are playing with I thought I should ask.
Donna
Oh, we have the internal kind in a class C.
Also, can we add an auxillary tank with a tube to the outside so
that we have more propane in Canada...there is a bbq grill gas
hook up there already. We want to add a 20 lb. tank. Do we
need a switch or something to switch from internal tank to outside
tank?
  • Old-Biscuit wrote:
    Inspect the TANK for rust...wire brush
    Inspect the hoses for cracks/weak spots
    Check fittings for leaks......soapy spray
    Clean it.....wipe it down
    Touch up paint
    Glad to see some caught it/got it right--tanks vs cylinders. Some propane vendors don't know.
    Propane cylinders have a re-certification requirement 12 yrs. after date of mfg. stamped on collar
    Propane tanks do not have this requirement......but it is recommended that 10 yrs. after mfg. date that the relief valve be replaced
    Okay, I've got to ask. Where is this recommendation in writing that the relief valve be replaced after ten years and how many of you have replaced yours at ten years?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Dutch_12078 wrote:
    There is no recertification requirement for the permanently installed ASME LP tanks typically used on motorhomes in the US period, end of story. Only the portable DOT cylinders more commonly used on TT's require periodic recertification. See the previously posted cites...
    Dutch I get the feeling you meant that for me.
    My post was in 2 parts.. in the Motor home part I mentioned inspection and re-paint as needed, Perhaps I should have been more specific inspection by the owner.
    I mentioned re-certification only under "Portable tanks" and clearly set the two sections apart.
    Of course, if you meant that for someone else.. Apologies now.
  • TucsonJim wrote:
    When a propane tank reaches 10 years, it MUST be recertified before it can be refilled. There is a manufacturing date stamped on the bottle. When it reaches the 10 year limit, just take it to a certified propane vendor and they can usually do the inspection and recertification.
    As others have stated, just make sure you take care of rust issues and you'll get a long life out of them.
    This is true for the removable bottles. The built in tanks attached to the RV frame are covered by a different set of rules and are exempt from this.
    Touch up paint
    It was in a Propane Council Education & Research Tech Fact Sheet....Link to download of that Tech Sheet CLICKY
    Replacing the safety relief valve was a mfg. 'recommendation' not a requirement by NFPA/ASME.
    One of those practical safety recommendations.
    And I doubt any have been changed out unless they were problematic.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
