TucsonJim
Aug 11, 2013Explorer II
I just traded in my 2004 Silverado with a 6.0L engine and 140,000 miles. I used it to tow a 10,000# FW in the mountains of Arizona to Montana. I replaced the factory oil with Mobile 1 full synthetic at 200 miles, then used synthetic for every oil change since then. I changed the oil based upon the Oil Sensor system. When the light came on, I changed the oil.
At 125,000, I developed a small leak over one of the rocker arm covers. I removed the cover and replaced the gasket. What was amazing was that the rocker arms and top of the cylinder head look brand new! There was no sludge what-so-ever.
I would not say I got any better gas mileage than anyone else, but I felt much more confident in the longevity of my engine when using synthetic.
I also had a 1989 Mistubishi Montero that I'd purchased new. My wife and I commuted in it over 100 miles per day. When I traded it in several years later, I had 245,000 miles on the engine and had zero work done to it other than routine timing belts per the owners manual.
I know this is anecdotal evidence, and others probably have similar results with petroleum based oils, but there was no sense in me changing from what worked.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
