Old-Biscuit
Oct 29, 2014Explorer III
Same sensors as OEM.......then why bother replacing?
OEM don't work...new ones same style won't be reliable either.
IF OEM are removable (not glued in place) you can just swap out the old for new.
If OEM glued in place (hot twist insert...zipped in place under high speed where tank wall melts around them securing/sealing them) then you will need to drill new holes and secure/seal them in place.
IF replacing probes........at least upgrade a little to Horst Probes.
Not very expensive, easy to change over from OEM and work better than OEM--------LINK
Another source of them--------LINK
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
