CavemanCharlie
Apr 09, 2021Explorer III
Before you swap out the rims between the trucks make sure the hole size (the part that goes over the hub) in the middle of the rim is the same. It's quite rare that it would be different but, there was one time; back in the day; when we tired to swap rims like that and found it would not work.
And, way ;back in the day; Dodges used to hare reverse lug bolts on one side of the vehicle. Don't twist them off. If the don't come loose easily try turning them the other way.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
