Trails_And_Tail's avatar
Aug 25, 2015
Are aftermarket tachometers reliable?
I want to install a tachometer on my 91 Class C with an EFI Ford 460 power plant. Are they at all accurate and reliable?
  • bgum wrote:
    Some are some are not. You get what you pay for.
    X2, there are good ones and there are bad ones.
  • go to Summit Racing... dot com.... a good one is worth the money..
    size is another matter. LOL.
    Anything you get will be more accurate than what you have now ;)
    And if it was slightly inaccurate, will you be even know????
  • Electronic tacometers just measure pules. Pretty simple device. You should be able to check calibration with a signal generator.
  • Don't know if that year supports an OBDI, but if it does, look at a scan guage. You can get the tach function plus about 20 others.
  • Some are some are not. You get what you pay for.
  • I would expect a name brand tach to be accurate.
    Mark
  • I have two in separate older vehicles and I have never had a single issue with mine. I too like knowing how many rev's my engine is making. Both were straight forward and easy to hook up, using a lead off the coil and selecting how many cylinders on the tach it self. Most come with good instructions and I hooked mine up so even the dash lights would turn on the back light in the tach. All the best, Hans
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
