batavia02's avatar
batavia02
Automatic levelers
Question folks. This may belong in the 5th wheel section but I put it here to get a wider answer. What are automatic levelers and for those units that don't have it how do they level if the automatic leverlers are not there ?thanks
  • Fifth wheel here...front landing gear, power. Back stabilizers, manual, crank down. I use 2x12 boards, beveled each end and pull up on them, lower side of trailer. I do it by myself, no big deal. On a good size motor home, the automatic levelers are very nice. On 26 to 30', there again, I just used boards to level with if no jacks.
  • I'm only familiar with the air suspension and hydraulic levelers that are on motorhomes (I believe electric versions also exist). The air levelers use the air suspension bags and inflate each as necessary to achieve level. Hydraulic levelers are hydraulic cylinders or "jacks" and are powered by a central pump or one pump per cylinder. Both automatic and manual versions exist (at least of the hydraulic types). The automatic levelers simply require a button push and they take care of everything (assuming not on impossibly sloped ground). The manual hydraulic levelers require the operator to push up/down buttons to achieve level.
  • manually.
    Boards under wheels to get even side to side
    Jacks whether on the fiver or separately.
