- ib516Explorer IIMine had it when I first got the truck, it was repaired under warranty.
Musky50 wrote:
Could someone explain ''Shuttle Shift'' I just bought a 07 Ram , Cummins and haven't towed with it yet. Just trying to learn something here.
Date: May 24, 2007
Models: 2004 - 2007 (D1/DH/DR) Ram Truck (2500/3500)
Overview:
This bulletin involves the replacement of the governor pressure solenoid valve in the transmission valve body.
Symptom/Condition:
The customer may experience a 1-2 shift transmission hunt during light throttle application. This condition may be due to a governor pressure solenoid valve.
Diagnosis:
If the customer experiences the above condition perform the Repair Procedure.
Parts Required:
Qty. Part No. Description
1 04617210 Valve, Governor Pressure Solenoid
4 05013457AA ATF+4 Automatic Transmission Fluid
AR 02464324AC Gasket, Transmission Oil Pon (Note: Original pan gasket is reusable and should not require replacement).
Repair Procedure:
1. Raise the vehicle on a suitable lift. Turn the ignition switch to the "OFF" position. Remove the ignition key from the ignition switch.
2. Remove the transmission fluid (oil) pan and pan gasket. Clean and save the pan gasket for later use during reassembly.
3. Disengage the wire connector to the governor pressure solenoid valve (Fig. 1).
4. Remove the screws used to secure the governor pressure solenoid valve retainer to the transmission valve body.
5. Remove the old governor pressure solenoid valve from the transmission valve body.
6. Clean the transmission housing and oil pan gasket surfaces.
7. Lubricate the o-rings on the new governor pressure solenoid valve.
8. Align the governor pressure solenoid valve to the bore in the valve body.
9. Install the governor pressure solenoid valve to the valve body.
10. Install the governor pressure solenoid valve retainer and attaching screws to the valve body.
11. Connect the wire connector to the governor pressure solenoid valve.
12. Install the transmission fluid (oil) pan and pan gasket (saved earlier) to the transmission. Tighten attaching bolts to 13.6 Nm (125 in. lbs.).
Fig. 1 Governor Solenoid And Pressure Sensor
1 - GOVERNOR PRESSURE SENSOR
2 - GOVERNOR PRESSURE SOLENOID VALVE
3 - ELECTRONIC GOVERNOR
13. Lower vehicle.
14. Add automatic transmission fluid to the transmission.
15. Verify correct transmission fluid level.
Policy: Reimbursable within the provisions of the warranty.
Failure Code:
ZZ Service Action - phenrichsExplorer
The shuttle shift is a condition where you will reach a certain RPM where the trans would normally shift smoothly up to the next gear but instead you feel it shift up and back down then up again several times very quickly due to a loss in pressure control. NOTE that it is not a loss of pressure, just simply a pressure governor getting weak. This is almost always when you are light on the throttle. If you give it more throttle you usually won't notice. The governor pressure solenoid issue is the cause of the 1-2 shuttle shift, generally if you are getting a 2-3 shuttle shift a band adjustment is due. You can easily fix a shuttle shift yourself as it takes only a minute or two longer than a trans fluid change. While you are in there you can adjust the bands yourself or at least inspect to see if any adjustment is possible. - larry_barnhartExplorer
srd357 wrote:
Thanks for all the info. I've been towing most of my life with a truck 4 speed and a 2 speed in front of that, gear splitting, 8 forward gears, all manual. For the last 4 years towing has been with an auto and I hate it. I'm considering, as my retirement truck, a new Dodge 3500 with a Cummins. It will more than likely be a 6 speed manual.
Thanks again SrD357
Ok so now buy it and be another happy camper. happy is good
chevman - Turtle_n_PeepsExplorer
If you have this issue you need to change out the governor solenoids.
PS there is a TSB about this you might want to check out at your dealer. - NC_HaulerExplorer
Thanks again SrD357
You asked about the auto tranny's and stated you're looking at a "NEW" Dodge 3500 with Cummins...The 68RFE is a very good transmission and comes with 370HP and 800 ftlb of TQ, BUT, you can go "one notch" higher with the Aisin tranny (a more robust tranny), and get 385 HP and 850 ftlb of TQ...Both are very good. Don't know what you're going to tow, but the manual tranny in the Cummins powered trucks is de-rated lower than the automatics.
Truck in my sig is my retirement truck and I got tired of shifting gears some years back while towing, thus I like the automatic "for me", better than a manual. - JIMNLINExplorer III
Hmmm, thats a new one on me. Many ag tractors use a shuttle shift but I've never heard of a shuttle behind a Cummins in a Dodge truck.
Now my NV5600 6 speed manual is a sycronized tranny. That allows down shifting/up shifting through the gears while rolling. - Musky50ExplorerCould someone explain ''Shuttle Shift'' I just bought a 07 Ram , Cummins and haven't towed with it yet. Just trying to learn something here.
- mileshuffExplorerHow good is the stock Dodge tranny cooler on the 2007 6.7L w/6 speed auto?
- srd357ExplorerThanks for all the info. I've been towing most of my life with a truck 4 speed and a 2 speed in front of that, gear splitting, 8 forward gears, all manual. For the last 4 years towing has been with an auto and I hate it. I'm considering, as my retirement truck, a new Dodge 3500 with a Cummins. It will more than likely be a 6 speed manual.
Thanks again SrD357 - boogie_4wheelExplorer
transamz9 wrote:
Very good post Boogie except for a couple things. Mine has held well over 400 hp towing 18,000# for years but for the rest of the stuff, you are dead on. My shuttle shifts are from 1st-3rd. All you have to do is push the go pedal and no more shuttle shifts.
Don't get me wrong, a major factor is how you drive them! I've got the 2-3 shuttle shift. Replaced the gov press solenoid and sensor (with another stock unit :S) and that didn't help. I just add a little more throttle to it to overcome that issue as well.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
