xzyHollyxyz's avatar
xzyHollyxyz
Axle Weight ?
I am looking at the spec sheet for my single axle 2008 Fun Finder X-160. Can someone please tell me what "Axle Weight (lbs.) 2043" means?
Thanks!
Regards,
Michelle
  • It lists a 'dry weight' of 2278#
    It lists a 'hitch weight' (dry) of 235#
    It lists a 'axle weight' (dry) of 2043#
    Sum of dry hitch & axle equals trailer 'dry weight'
    So axle weight is the weight of trailer on axles (dry)...no weight of any options, LP, water
    It lists a GVWR (max weight) of 3335# so axle is probably rated at 3000# (max weight on axle)
  • If it's just"axle weight" that would be the weight on the axle when empty. If it's gross axle weight then it's the most you are allowed to place on the axles. If you overload then able damage can occur causing excessive our uneven tire wear.
Looking for advice before your next adventure? Look no further.25,156 PostsLatest Activity: Aug 12, 2025
