Flapper
Jul 07, 2017Explorer
Back from the scale, but did I mess it up?
Trying to figure out if I have loaded my TV front too little, enough, or too much - but the results confuse me. I have the WD bars set to return the front fender rise back to the unloaded height. Ford says recovering 50% of the rise is acceptable. Here are the numbers:
Truck only: Steer = 3560, Drive = 2840
w/o WD set = Steer = 5560, Drive = 1780, TT = 6640
with WD = Steer = 4180, Drive = 3020, TT = 6780
?? It seems like with WD on, I actually am losing weight from the front, and moving it to the back. Or is it likely that I was not on the scale correctly, and the drive axle was partially on the front axle section of the scale during weighing? (each weigh was a separate pass, so positioning very well could be wrong for one, or both)
