- owenssailorExplorerI have had both types. I find the Equal-i-zer branded hitch much better. I also found if the bars are square to the L brackets the noise is greatly reduced. Also - you don't have to take the sway bar addon off when backing up. Much better.
- DutchmenSportExplorerHad both types. Both worked great. I feel bars are easier and faster to hitch up. My opinion only.
- downtheroadExplorerHad both....both worked well. The key is getting either set up and dialed in correctly.
I prefer chains...they are quieter. The Equal-i-zer we had on a previous trailer scared my wife - it squealed and screamed on tight turns and backing up. - CampteacherExplorerYou'll get all kinds of responses to that question, as members here have many different types and brands. What size of trailer do you have?
Equalizer is a common one, they have bars. You'll also see Blue Ox, which has chains. Both have built-in sway control. On the other hand, my trailer, which is being traded, had the basic L-shaped bars that connect to the frame with chains, and an anti-sway bar. It served me well for six years.
My new trailer (8250 GVWR) will come with a Husky Center-Line, which uses bars.
I look forward to seeing what others say.
thanks!
Kevin
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
