DD716TED's avatar
DD716TED
WDH Round Bar chain hardware??
I recently removed the u-bolts and chain that is attached to the round bars so I could preserve and repaint them. After repainting the bars, I realized that I had accidentally thrown away the nuts that u-bolts used the chain to the bar. Is there a certain type of hardened or stronger nut (or self locking) nut that I should purchase to reconnect the u-bolt / chain to the bar? Asking as I realize how much pressure is on this u-bolt / chain.
  • Woodtroll wrote:
    4aSong,
    Not sure, but I think that drilling those holes may be a real bear. Those bars are hardened and tempered after shaping and drilling, and I think they are going to have to be really hard out at the chain end in order to hold their shape, like any other spring steel. Might be worth a "test drill" on one before you invest a lot of planning or effort.
    Good luck!
    Regan
    You bring up a good point, I will need to do some additional research before proceeding.
  • 4aSong,
    Good luck!
    Regan
  • I would also recommend the lock-nuts and/or grade 8 nuts with loctite.
    I have a question, I have a spare set of round bars rated at 800lbs which I would like to alter by adding chains to use with my E-Z Lift hitch system, I plan on drilling two holes in each bar for U-Bolts and adding chain, is there a certain type of hardened chain and u-bolts that I should be shopping for, as DD716TED stated above there is a considerable amount of pressure on the u-bolt / chain.
  • Me? I'd use Grade 5 or Grade 8 nuts and blue Loctite.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
