rhagfo
Jan 09, 2016Explorer III
D.E.Bishop wrote:
I've got to agree that you will need to remove the motor and fan blade and see if you can use a pen oiler to place a drop of oil on the bushings. Many of the motors have concealed bushings so replacement is most likely what you will need to do. The cost for the motor is about $34 US. It is not likely that touching the motor or turning the blade would fix a bad connection. The odds are it is a dry bussing in the motor. So good luck and keep warm.
That or you could replace it with a better unit at only about twice the cost of the motor that moves a lot more air.
Vortex fan upgrade
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
