ocbms's avatar
ocbms
Battery Cutout switches and dead batteries
I was the the factory for some warranty work and concerns this week. The night before going to the factory, I was in a campground and we talked some issues.
One issue was my batteries would die over about 3 week period with the both the Main battery Cutout and the Invertor power switches off. The fellow camper told me, he had the same problem and found a remote Generator Start Module (even thou he didn't have a on board generator) that had a constant drain to the batteries. He pulled the fuse and problem solved.
I passed this remedy on to the Factory Tech, He in turn was able to find the same connection plus a Battery Monitor Module connected for constant drain. We talked of putting addition cutout/on-off switch in those two device circuits but the company policy is this would be a modification and not warranty work. I was told pulling the fuses was a valid option, My wife could not have pulled the fuses.
I say Engineering Design deficiency but anyway I was given some hardware (matching existing switches) should I choose to install and now it is just when.
Also I will a small engraving telling of 3 places to Cut the DC Power.
  • Yeah the Auto Generator Start should be disabled when the batteries are disconnected. On our coach the only thing hooked to the batteries when disconnected is the solar panel.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
