rtaylor0830's avatar
rtaylor0830
Battery help
I have been camping for years but I have never really boon docked. So I have noticed that on my 2011 camper that as soon as I unplug it from shore power the battery does not stay charge long at all. Is there anything I can do or does the battery need to be replaced and if so what kind should I get. Seems odd for a battery to go bad so quick
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are several issues possible.. For one: What converter do you have. Some are better than others at making a battery last and last, Some are not good at all, And how long do you leave it unplugged between trips.. As others have said parasitic draws will take a battery down in a relative short time, Lifting the negative cable or a battery cut off switch can help here big time.
    Next: If the battery is not a maintenance free design, when was the last time you checked the fluid level? The fluid is a dilute acid and you may need to add DISTILLED WATER, the level should be between the top of the plates and 1/8 inch from the bottom of the filler tube (Leave a 1/8 inch gap).
    Finally there is the size of the battery itself.. A common battery in small trailers is a group 24, about 75 amp hours, Marine Deep cycle you can safely use only around 20 of those amp hours before serious battery damage happens.
    I just dropped (Well lifted) a pair of Gold car batteries into my house battery pair. 230 amp hours. I can safely use 115 of them before serious damage happens. Clearly it takes .... a bit longer... to run these puppies down. That is over 3 times the Group 24, it is about half my total battery capacity and being true DEEP CYCLE I can use more of it. (Soon as I replace a fuse I popped today or Thursday).
    The six volt golf car battery, used in pairs, in series, so that you end up with one 12 volt (bat)T(ery) (Bat is six volts. T is a jumper and ery is another six volts making one 12 volt battery) are so popular because golf courses order them by the pallet load for their golf cars. making them less expensive overall.
  • How long is "not long at all"?
    Is everything turned off or are you using the trailer like normal?
    Can you tell what the voltage is when you first disconnect the utility power?
    For boondocking, you may well want 2 batteries, the heavier the better.
    Do read gbopp's link.
  • If you've been just unplugging for four years, you battery is toast. There are parasitic draws that will draw down the battery in a few days, You need a new battery and a master disconnect switch.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
