GordonThree
Apr 10, 2014Explorer
I'd disconnect your batteries and inspect them for damage, check the water levels and try charging them with a regular automotive charger.
Worst case scenario is one or more of the batteries is ruined, and has formed a short circuit. This is bad because it will heat up the battery something fierce, and could cause rupture, making a big mess.
It could also be something simple like a corroded terminal on the switch, or on a battery, not letting the full voltage through.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 04, 2026
