Boon_Docker
Sep 19, 2020Explorer III
2oldman wrote:Campinfan wrote:Here's what I got from its specs:
Is the A/C power there to charge the battery?
" Just plug it into an AC outlet to connect directly to the RV’s AC system. It will convert DC to AC with DC inputs between 10 to 15 volts..." It also states there is no charger.
I don't understand. It's not a charger, but why it's plugged into AC I don't know. Maybe that means you plug an ac wire into it, and their wording is confusing. Nothing about its having a transfer switch.
That is for the pass through. When plugged into shore power the 120v bypasses the inverter and goes to the load the inverter is connected to.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
