Frozen001
Jul 21, 2021Explorer
Bent WD snap up bracket on dual cam setup.
So on our way to Tennessee, I bent the drivers side WD snap up bracket for my Reese dual cam setup. I believe it was caused when we left a gas station that had a down hill to the road and then the road was up hill, creating a “v”. I was also truning and it must have put a lot of pressure on that side.
I got a replacement, but a couple of questions:
When the bracket bent it led a small dent in the box where the bolt that was holding it place was. What should I do about this? If I had to guess it is about 1/4” deep and maybe 1/2” circle. I can snap a photo tomorrow am and post.
What can I do to prevent this other than staying clear of that odd entry/exit. I see Reese make a heavier bracket with gussets on them… is it worth replacing my current two with these? As a side note… I posted about a month ago about the drivers side seeming to have more tension that the passenger side. Not sure if those event and that are related… but makes me wonder.
