time2roll
Feb 15, 2019Nomad
If your 500 has a liquid out connection you most certainly can fill the RV tank.
Otherwise yes you can run propane into the shed and connect to the RV. Probably need a regulator outside so you only have low pressure in the building. Your contractor should know the local rules. By all means get a city permit and inspection.
