JaxDad
Feb 16, 2019Explorer III
If it’s only for a ‘what if’ type situation put the ‘Extenda-Stay’ on the M/H and a quick disconnect on the tank then buy a line long enough to reach that will just lay on the ground if & when needed.
Be aware though the 60’ you mention is likely moot since you can’t run things like your furnace inside an enclosed building unless you leave all the doors wide open.
