LJAZ
Feb 17, 2021Explorer
If you're replacing the range hood anyway you might consider the Fabulous Operating Products range upgrade kit. Its made by the same people who were the original owners of the Fantastic Fans. Remove the fan housing the frame and install their upgraded unit. It's got a quite 3 speed fan moves a lot more air and has an LED light with 2 brightness settings. It also has a vent that can be opened/closed from the inside. Cost is around $200.
I did this upgrade a couple years ago because DW loves to cook and was constantly setting off the smoke alarm. After replacement no more alarms.
My original hood was a Hengs brand with the fan box spot welded in place so replacement was a bit tedious but not complicated. Other brands have the box screwed on which makes replacement much more plug and play.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
