Lowsuv's avatar
Lowsuv
Best Value Portable LED Lantern ?
Our portable Coleman battery fluorescent lantern suffered a mishap last month while camping at bullard's beach .
We have made the conversion from Maglite flashlights to LED flashlights .
There seems to be a quality difference between the LED flashlights . Some good , some much better .
Who has purchased a Portable LED Lantern for camping and has found a choice that is better than most ?
Is there a good LED lantern that uses 3 or 4 "C cells" or "D cells " ?
Where did you find it ?
  • Our old LED lantern bit the dust and I had a gift card for REI so picked up http://www.rei.com/product/861164/ultimate-survival-technologies-30-day-lantern-
    It uses 3 D size batteries and puts out 300 lumens on high. I am using rechargeable batteries and the charger will be powered by our solar panel.
  • I received the Coleman Duo LED Lantern as a gift. I've been happy with it. While it doesn't receive heavy use, when needed, it has served its purpose well.
    A 4-panel lantern is also sold, but for DW and I, the 2-panel has worked just fine.
    Hope this helps.
  • I have not found an LED lantern online yet that looks like it's worth buying.
    What I ended up getting was a fluorescent that takes the same rechargeable battery used by my cordless drill, and also portable tire inflator.
    Just a suggestion for something you could check out - if you own any cordless power tools, see if there's a lantern available that takes the same battery.
    PORTER-CABLE 13-Watt Fluorescent
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
