profdant139's avatar
profdant139
Explorer II
Jul 19, 2015
BFG A/T KO2 Load Range E: what psi for towing?
So here is the backstory -- I drive a nice little Tacoma v6 4x4, and I tow a little 2500 lb. trailer. So why did I just buy a set of massive BF Goodrich All Terrain KO2 in Load Range E (LT 265/75R16)? I'm glad you asked!
Here's why -- we often boondock in places that seem to specialize in very sharp rocks. (The Sierra, the Cascades, the Wasatch range, the Rockies . . . very pointy places.) Originally, I rejected the Rugged Trails that came with the Tacoma, and the dealer put on Rugged Terrains, which were ok. But when we recently got a puncture right in the middle of the tread while gently off-roading (I don't go over 20 mph off road), I said, "That's it. Give me tank treads." (We changed the flat ourselves, and it was kind of fun, but it took us a long, long time to do it right and to do it safely. Not a good use of our limited recreational time.)
I am quite sure that my mpg will take a hit from these new tires, and that they will be noisier than my old tires. I am happy to live with those effects, if the 10-ply tires will reduce the chance of an inconvenient flat. Plus we do enough mud, snow, ice, gravel, and sand driving to justify the knobby tread. (I don't care how funny they look on my little truck, like big hiking boots on a skinny little boy -- these tires are not for show.)
The PSI recommendations on the doorframe are for the stock tires, which is meaningless with these new monster tires. And the BFG website is also useless, surprisingly. I did the usual Googling, with partial success. I learned about the "chalk" test, which I used to figure out my everyday PSI -- I took a yellow crayon, drew a line across the tread of all four tires, drove for a hundred yards, and determined that I had overinflated the tires (at 60 psi) because the crayon wore out in the center of the tire before the sides. At 50 psi, the lines wore out uniformly. This test took me about an hour of trial and error, slowly cruising up and down my block -- the neighbors must think I am going crazy. For everyday driving, I'm going with 50 on the front and 55 on the rear, since the door sticker had a 3 pound difference for the stock tires, and these are substantially beefier than the original equipment.
I suppose I could hitch up the trailer and do the same test while towing, and I probably will have to do that at some point. But I am hoping that someone else has already figured this out and can save me the trouble! And while you are calculating the proper PSI, I assume that the front and the rear will be different, but by how much? (By the way, the max PSI under full load is 80.) I am guessing 75 psi in back and 65 in front, but those are just guesses.
Thanks in advance for your advice!!
(PS -- dear moderator, if this should be in "tow vehicles" rather than "towing," please feel free to move it. I took my best guess -- it looks like more tire discussions end up in towing than in tow vehicles.)
  • rhagfo's avatar
    rhagfo
    Explorer III
    Old-Biscuit wrote:
    With that 2500# trailer (tongue weight of what------300#?)
    I would just run 50 psi front and 55 psi rear all the time.
    It's not like you are piling on huge weight increase from non-towing to towing!
    Those tires likely have a 3,415 load rating at 80 psi, how much do you weigh on your rear axle?? Maybe 2,550# likely less.
    With sharp rocks where you boondock I would think 45 to 50 psi, and that is likely too much!
  • Rear may need 10-15 lbs more, at most. Fronts probably nothing at all.
    marty
  • With that 2500# trailer (tongue weight of what------300#?)
Looking for advice before your next adventure? Look no further.25,189 PostsLatest Activity: Mar 27, 2026
