jimw606
Nov 25, 2013Explorer
bias ply tires
It appears that the R-Vision I bought, has Bias ply tires.
Should I go back with those or Radials. Thanks Jim
blt2ski wrote:
Only 19 failures of Maxxis?!?!?! I think I have had more michiblows blow up in 30 some odd yrs of driving than that! I have yet to have a Cooper or Toyo blow up. Every other brand I have owned has had at least 1 blow out!
Marty
atreis wrote:
My trailer rolled on OEM chinese bias ply tires for 5 years, until they wore out. I replaced them this past summer with chinese radials. I do like the radials better, but not so much that I would ditch the new tires that come with a trailer.
In terms of brands - I'm firmly of the opinion that if the weight on EACH TIRE is under the tires' rating (yes, this does vary depending on how the weight of the trailer is distributed and how level the trailer is front-to-back while being towed), and your speed is below the max speed rating of the tires, and you keep the tires properly inflated, and you don't run over something that punctures them, they're not likely to fail regardless of brand.
fla-gypsy wrote:CKNSLS wrote:jimw606 wrote:
I like Maxxis also. Having trouble finding 2 205/75R/14's.
I did have one of the Maxxis on my 5ver fail with a broken belt. Only worn about 20%.Had to jump through hoops to get it replaced,
I have thought about 15" wheels and also looked at Kuhmo 857's in 14"
I have been researching tires and it seem they all have problems.
I bought this 2007 FX189QB and brought it home Saturday. Discount Tire in Dayton only had 1 Maxxis so I came home on the old tires. MFG 1006
I did not realize that it had Bias ply until I was looking at it this AM. Just thought I would ask the Pro's. Thanks everyone. Jim
That's Maxxis tire failure number four posted on this board. (Yes, I am counting).
What a boring pastime, 4 whole failures that could easily have been neglect or road hazard generated. If you want to count Duro Brand failures you could at least be entertained.
Further examination reveals, that weight rating on the side of the trailer, GVWR etc, is for 205/75/15C1 tires.
I feel really sure that the current tire and rims are original.
I am thinking the Kumho 857's are looking better.
We are not going anywhere soon, so I have time to shop.
Kumho 857 is a good choice. Tire Rack has them.
