Ritkei's avatar
Ritkei
Black holding tank won't drain past 2/3
After 4 days of camping we have a full holding tank. I open the black valve and hear a rush of fluids for about 1 min, then nothing. Check the tank level inside and it shows 2/3 full. After searching I found a post that suggested filling all grey tanks and pull all the valves at same time, causing enough of a vacuum to get the holding tank to drain. This worked once and now I'm stuck at 2/3 full again. Never seems to drain below 2/3 full. Any ideas or tips tricks?
