tompla's avatar
tompla
Blue Tooth Electric Brake controller
I have a 40 ft Class A MH. I am going to pull a trailer with electric brakes. Curt makes the Echo mobile Trailer break controller that plugs into the 7-way plugin on the back of the coach and then you plug the trailer brake into that Echo Device. The device is managed thru Blue Tooth as an app on your phone. I am concerned if Blue tooth will have a strong enough signal when my phone is with me on the dash. Has anyone had any experience with this type of set-up?
  • JRscooby wrote:
    schlep1967 wrote:
    Your phone is not controlling the brakes. It is manged by your phone. Managed as in you can use your phone to adjust the amount of brake applied. Like adjusting the dial on a regular brake controller. When you plug in the 7-way plugin and apply the brakes the plugin/brake controllers inertia reader will adjust the amount of voltage applied to the brakes. I'm sure it would use the settings previously applied if the bluetooth signal is lost.
    I might be OK with this, but need to understand Why? I hook up to a trailer, and adjust the settings for that trailer. If I only pulled 1 trailer, never need to adjust. Why would I richard around with a phone to make adjustments?
    Because everything is better with Bluetooth...
    I saw this yesterday and was confused so I looked it up.
    The primary thing is to adjust the brake controller settings thru the phone. That should be OK as you shouldn't need to change those often and worst case, you should be able to take the phone and walk to the back while parked and make an adjustment. They say that once set, it remembers the settings if the connection is lost.
    But it also has the manual trailer brake application thru the phone. If you do any driving in the mountains, this is a deal breaker for me as there are times, I will use the trailer brakes independently and I don't want to find out it's not connecting when it fails to connect.
  • Just when I thought that brake controllers couldn't get any dumber, they come up with this. How do you manually control the trailer brakes?
    One thing I like about my more 'analog' controller is the ability to force application of the brakes if needed (surge them). That would be a lot more complicated or impossible with a phone.
  • I would not trust any wireless solution for brake control. Murphy's Law dictates that the one time you'll really need it to work, the signal will cut, or your phone will crash or whatever.
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 26, 2025
