Ivylog
May 31, 2021Explorer III
Doubt after a couple of trips you’ll be monitoring all that often. I opted for a $42, 500 amp monitor for my 600AH of DIY Lithium batteries. Once the BMS stopped charging them I set the AH to 900AH... it keeps track of usage, %, charge/discharge amps, and voltage...all the info I need. Helped that the display was easy to locate in the BR.
Monitor
https://www.amazon.com/CAMWAY-Voltmeter-Backlight-Waterproof-Motorhome/dp/B088RG27LS/ref=mp_s_a_1_10?dchild=1&keywords=aili+500a+battery+monitor&qid=1622487745&sprefix=aili+&sr=8-10
Monitor
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
