mikestock
Jul 09, 2021Explorer
I did as Mike Brez suggested and watched the cylinder activate as I applied the brake.
You need to carefully set it up when installing to make sure the brake light in the toad is just on the verge of lighting when you test it.
This is, of course, just following the set up instructions. Just holding the box after setup and tilting it forward tells you it's working if the rod extends.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
