restlesswind's avatar
restlesswind
Brake Controler Problem...Update
My SIL has a Prodigy brake controller on his Ford P/U. ('05 4wd 3/4)
The brakes on the trailer work using the manual control but no trailer brakes when pressing the brake pedal on the truck.
Any advice?
After checking all that the instruction book called for SIL found the book!) we narrowed it down to the controller itself .New one on order.
Thanks for all the help and advice, we both learned a lot.
    Any advice?
    BTW I was wrong on the year of his truck, it's an '03
  • The controller has a 4 wire hook up. Power, Brake, Brake Sensor and Ground. Since it operates manually, power, brake and ground are OK. A disconnected brake sensor wire could cause your symptoms.
  • cbenn wrote:
    Let me save you some time, on your Ford if you can stop the trailer with the controller and not with the brake pedal your TBC pressure transducer is out, it is located directly under your master cylinder, there are 2 sensors there, the front one is more for the brakes/cruise control, the second one is the transducer for trailer brakes, ford carries them at a whopping $154.00, go on line and should find them for around $100.00. Hope this helps you out.
    I think you are referring to the built in Ford TBC? The OP has an after market Prodigy controller.
    We will hook up the trailer tomorrow ,get the volt and current meters out and get some more information.
    Artum Snowbird....That was my first thought. Unfortunately, he has lost the instruction book. (?)
    Something else to know. Press the brake pedal while Sitting still. and the Prodigy will send little to no current to the TT brakes. It works on inertia / movement. No inertia no need to send current. May be hard to check. IF you turn on the boost to 3. You can get a current for a second, until the Prodigy learns the TT is sitting still.
  • Let me save you some time, on your Ford if you can stop the trailer with the controller and not with the brake pedal your TBC pressure transducer is out, it is located directly under your master cylinder, there are 2 sensors there, the front one is more for the brakes/cruise control, the second one is the transducer for trailer brakes, ford carries them at a whopping $154.00, go on line and should find them for around $100.00. Hope this helps you out.
    Any advice?
    Do his brake lights come on? The TT brakes are activated when the TV brake lights come on.
    This!
    Sounds like his brake lights dont work.
  • We will hook up the trailer tomorrow ,get the volt and current meters out and get some more information.
    Any advice?
  • Are you saying the trailer brakes work when he swings the brake controller but does not when he steps on the brake pedal? The voltage to the brakes comes from the same place, down the same wires. Has he set up the controller to the recommended setting? What is the trailer weight.. perhaps he needs to adjust the level somewhat, or the boost?
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
