lanerd
Oct 05, 2014Explorer II
Gonzo42 wrote:
I want to get a small car for a toad and I'm trying to get info on a brake controller system that actuates the (hydraulic) car brakes via the controller.
Does such an animal exist? I see electric setups only, so far.
Would this mean a hydraulic brake fluid line from the RV? I'm not liking that. Or is there a solenoid actuated system the the toad?
Along with that, can I wire the trailer 7-pin connector on the RV to actuate the running lights, brake lights, turn signals on the toad?
We use the US Gear Unified brake system (SEE HERE). It is a combination type of unit that utilizes an electric signal from a small monitor that is mounted on your dash board and it activates a small vacuum pump that you mount under the toad's hood and connected to the power brake vacuum line. This allows you to use the power brake system of the toad for stopping power. The electric line also activates (at the same time as the pump) a small electric solenoid that has a cable connected to the brake pedal. It is fully proportional and can be adjusted for the amount of braking power you want applied to the toad's brakes.
It is all electric, but does activate your toad's power brakes. The initial installation is a little involved, but once there, it is invisible, adjustable, and requires NO other attachment of wires, hoses, or anything else. The electric line runs through the 7-pin connector as does the toad's tail, brake, signal, and emergency flashers. It also has a 12vdc line that keeps the toad's battery charged while towing and the emergency breakaway switch is included.
I have used mine in three different toads and two different motor homes.
Hope this helps
Ron
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
