riven1950's avatar
riven1950
bright light for range hood?
We are looking for a way to brighten up under the range hood.
Is there an led light that is brighter than the original?
Ours is a 12 watt bulb. Push in type, I think it is 921
We do not boon dock so led is not required from a power standpoint, but the fixture says 14 watt max so I don't think another regular 921 will change things.
suggestions appreciated
  • I replaced the original 921 bulb with a 24 5050 LED bright white panel light that I bought on eBay. DW likes it.
  • I used the same thing Off Pavement uses, I went with warm white and it has given a softer brighter light.
  • I ordered a few sample LED panels and decided on warm white for the interior lighting. One of the samples was a bright white 48-5050 panel which got installed in the hood fan. Lots more light than the 921 bulb.
  • Did bright led's for our range hood and refrigerator.
  • I replaced ours with LED bulbs that are not only brighter, they do not get hot, and use much less power. Bought them at local RV store. The ones I got are flat panels.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
