wanderingaimles
Sep 05, 2017Explorer
can you see the holes that the staples have to re-enter? If so, can you insert a toothpick and a drop of glue into the hole, press the trim piece with the staples into place (it should need to be tapped in with a hammer or a board, if not its too loose) and then use something heavy to hold pressure keeping it in place until the glue dries. (overnight)
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
