wanderingaimles
Sep 05, 2017Explorer
no, my staple suggestion is to leave the staples in place on the cover piece. The toothpick, you only put in about 3/8 of an inch with the tiny part pointing out and a drop of glue. You then place a board over the area where the staple is under and tap the staples back into their original holes which are hopefully slightly tighter and let the glue dry to keep the staples in place.
My only other suggestion would to check for a local upholstery shop that works with boats and other items to let them repair it. Since the motorhome can be taken to their shop, it shouldnt be too expensive.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
