Gonzo42
May 13, 2019Explorer
The easiet solution is probably using an Eazy-Out. First you drill a pilot hole in the broken bolt then put the Eazy-Out which is threaded left-handed, tap lightly with a hammer, then turn it with a wrench to remove the broken bolt.
Get yourself replacement hardware from ARP, which has the best product for strength.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
