schlep1967
May 14, 2019Nomad
Unless you have a good deal of experience, this is a job for a professional. An easy out may work but it will most likely take a lot of heat on that area to have any chance. Those bolt heads broke off for a reason. The bolts are rusted into the holes and you are very likely to break off the easy out. Once that happens and you now have a hardened chunk of steel in the middle of the soft bolt you need to get drilled out, the professional is going to cost even more.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
