DutchmenSport's avatar
Sep 08, 2019
Bugs...
Two years ago we got hit with the dreaded "stink bugs". They invaded everything. Our travel trailer had stink bugs for the next year inside. I caught them and one-by-one set them free outside. If I killed them, they emit a horrible smell, so killing was not an option. Even after winter ended, in the Spring, the bugs were still here.
We traded that travel trailer for our current 5er. It was September last year, and immediately, the new 5er was taken over by a new crop of stink bugs. Again, capturing them one at a time, it never ended. Winter came and went again. Because we used the 5er over the winter, we'd see stink bugs almost every day. Just couldn't get rid of them.
Finally, in the Spring of this year, I took aggressive action and set off 3 bug bombs inside the camper all at once. About 6 hours later we returned to the 5er and I started counting the dead stink bugs that appeared and were found everywhere! That first attempt at a bug bomb resulted in over 60 dead stink bugs on that first day. Over the course of the next few days, we found an additional 40 (plus) that eventually died because of the residual bug bomb mist that was everywhere settled.
Two weeks later, I set of 3 more bug bombs, and this time it produced about 10 more dead stink bugs. It seems they came crawling out of everywhere they were hiding. Since then, we've had no more stink bugs, but I do occasionally find dead bodies in strange places, inside a cabinet, under the couch, rolled up in the outdoor mat, in the bottom of the tub under the sink. Fortunate though, they are all dead now.
However, today I decided to do some window maintenance. After one year, the sliding windows are getting hard to slide so picked up some 3-in-one RV Care Window Track Dry Lube. I also discovered today that all the screens on my windows are on sliding tracks, same as the window. So, when I sprayed with the window lube, ..... guess what? yep! It blew out MORE dead stink bugs that were caught in the window tracks.
Now, it's vacuum sweeper time to suck out all those dead bugs caught in the window tracks under the screen sliders. Shesh! Who would have thought!
So, just a helpful suggestion here... if you take the time to clean your windows or do maintenance on them, remove those screens and get a vacuum sweeper hose and suck out all the dead critters that found a home ... and a grave yard there. You might be surprised what you find in that unseen track!
About the time I thought I found all the hiding spots for those dead bugs, this one unearths. Anyone else have any more suggestions where bugs hide and die?
  • We had a millipede invasion last month at home and in the garage. I used a wet dry vac in the garage. I'd suck up 100 or so then go out a hour later and get another 50. Lasted a couple of weeks. Now my wet dry vac is never coming back into the house. Even after a massive pressure washing (motor and all) it still stinks. The 300 MPH crash into the vacuum just implanted the smell but they lost. Home Depot won. I need a new vac.
  • If you have slides, look under there. We had the same problem with ladybugs, vacummed up several bags full of them, and still see some occasionally. Our front slide has carpet which covers the edge we raised that up and found hundreds. We had a small hand vac, (dustbuster type) and just about wore it out. But it was the only thing that worked. If you should get this type vacuum, be sure to get one with an extension hose and nozzle. The flex hose is much easier to use and to get in corners.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
