SolidAxleDurang
Nov 04, 2015Explorer II
mkirsch wrote:Dick 641 wrote:
I have a 2015 GMC 3500 an just checked mine is the same way, what was the end fix to get it flat on the bed?
Install it properly.
From what I've read here, it sounds like the installers just slapped the B&W hitch in and tightened the bolts down without making sure the ball was vertical. There is a little slop in the holes and a tiny lean forward or back on the ball would translate into the companion hitch not sitting flat in the bed.
What I would do is install the B&W hitch loosely, install the companion hitch in place to hold the B&W frame in the correct position, and finally tighten up the bolts.
I think most people read something totally different.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
