outwestbound's avatar
outwestbound
calculating trailer vs 5th wheel towing capacity question
Sorry to be a pest, but another question to check on methodology; not really interested in a Ford vs RAM truck dust up. I'm looking to buy a 1 ton to tow a 5th wheel. I want to know the math behind a manufacturers published tow ratings between conventional towing (tow behind) vs. a 5th wheel. It's confusing as Ford publishes these two different ratings, but RAM does not appear to. RAM is just one tow rating number and, since I'm not sure about the math and best practices, I don't know how best to interpret RAM's figure.
For example, Ford's 2014 diesel F350, auto transmission 4x4 6.7L DRW 3.73 axle ratio is conventionally rated to tow 18,500 and on a 5th wheel, 22,200. It looks like Ford took 20% of 18,500 and added that back, to get 22,200 (18.5 + 3.7=22.2). I'm guessing this 3,700 pin weight was allocated to the tow vehicle, thereby increasing the 5th wheel tow rating.
Am I correct? If so, how many times is the pin weight counted in the GCWR? (e.g., is the 3,700 pin a deduction from both truck and trailer; a total 7,400 against the GCWR?)
RAM's comparable 2014 3500 AISIN (auto transmission) DRW 3.73 is rated to tow 23,500, based on the chart in the marketing brochure I got at the dealer. RAM just provides this one figure, so how does this single figure compare to Fords' fifth wheel figure? I just want my calculations to be apples to apples, not looking at brands here, with the intent of towing a 5th wheel.
Thanks
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
