icanon
Jan 31, 2015Explorer
kennyzzz wrote:
some reading for you, hope it helps.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25572537.cfm
ps it helps if you tell what you tow with.
ps # just trying to help
Thanks I'm reading this link now.
Towing with a Dodge Ram Laramie 1500 Quad cab 5.7 Hemi with 3.92 diff. with 4 corner air suspension. My new trailer in which I'll be picking up this spring is a Kodiak 290BHSL with a unloaded TT of 6,005lbs and a TW of 781 lbs.
Assuming I load it to the max load of 1,500lbs therefore I'll be around 7,500lbs but the TW is were I'm trying to respect to a max of 960. After reading many blogs and forums about whether or not to install a WD and/or Sway control has me wondering what route to go? I believe and my thoughts that there is no harm in installing a system like equalizer only to benefit if there is any, any problems that can occur out on the road.
Thanks for the reply. Will update my signature to reflect my rig :-)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
