jaragonExplorerMay 16, 2013CAMCO EAZ-LIFTI have a 2008 Keystone Passport that has the axles flipped so it sits a little bit higher than normal. My question is I recently purchased a EAZ-LIFT weight distribution hitch for my 2010 RAM 2500. ...Show More
Ron_GratzExplorerMay 16, 2013Sounds as though you need to lift the TV/TT higher before hooking up the chains.Are you using the tongue jack to lift the TV/TT?If so, have you tried putting a block under the tongue jack so you can lift the TV/TT higher?Ron
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
Related ContentCamco EAZ-LIFT R6 TT HitchEAZ-Lift TrekkerEAZ liftBent sway control on EAZ Lift hitchEAZ Lift weight distribution
