I have a 2008 Keystone Passport that has the axles flipped so it sits a little bit higher than normal. My question is I recently purchased a EAZ-LIFT weight distribution hitch for my 2010 RAM 2500. ...
Of course picture can be misleading but for starters it looks like the front end of the trailer is too high. It should be level or slightly lower in the front. Another is that it appears that the lift brackets are not directly above the u-bolts on the bars. Did the weights and measures change when you mount battery(s)? Most people do not worry that the back end drops a little. They try to get the front axle back to its original height.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
