I have a 2008 Keystone Passport that has the axles flipped so it sits a little bit higher than normal. My question is I recently purchased a EAZ-LIFT weight distribution hitch for my 2010 RAM 2500. ...
I got the ball assembly put together this afternoon. Heading to the parking lot tomorrow to set the bars. I have a some questions.
How could I know what angle to set the ball assembly at when assembling if I don't know where I need it to be? To reset the angle is no small feat, having to undo the 2 bolts through the shank, loosen the set screw, then reset the thumb screw...then tighten every back up again. The angle of the assembly is to adjust the angle of the bars, is that correct?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
