schlep1967
Aug 02, 2021Nomad
Gdetrailer wrote:
Neither.
Those are solutions looking for a problem and I can't see any way you can use wheel chocks to hold the wheels in place (pretty dangerous) with those devices.
Not to mention you really want both axles to be lifted at the same time.
You obviously don't know anything about the Andersen Levelers. Once you pull the tire up on the rounded leveler, you put a chock under the narrow end. Basically putting the tire in a cradle. You then also chock the other side.
And lifting both axles at the same time really doesn't matter. You probably don't want to lift one 6 inches with out lifting the other but lifting the 4 inch height of one of the levelers will not hurt anything. And quite often if I am only off one to two inches or so I will use only one leveler.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
