Cummins12V98
Aug 02, 2021Explorer III
Get a Laser Level and set your RV perfectly level by adjusting the frame so all four corners of the bottom of the frame are the same distance to the Lasers line. Now adhere levels like pictured above in the "LEVEL" position. Even with my 6 point system I check my little levels to manually adjust my RV when I am still hooked to the truck.
MUCH more accurate than the big bearing in the curved tube!!!
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
